Use the Authenticator Configuration table to display configuration objects for the Authenticator PAE associated with each port.
- Select 802.1X - EAPOL.
- Select the Authentication tab.
Authentication Field Descriptions
Use the data in the following table to use the Authentication tab.
| Name | Description |
PortNumber |
Indicates the number associated with this port. |
ReAuthEnabled |
Indicates the re-authentication status of an existing supplicant at the time interval specified in ReAuthPeriod. The default is false. |
QuietPeriod |
Indicates the time interval (in seconds) between authentication failure and the start of a new authentication. The default is 60. |
ReAuthPeriod |
Indicates the time interval in seconds between successive re-authentications. The default is 3600 (1 hour ). |
RetryMax |
Indicates the maximum Extensible Authentication Protocol (EAP) requests sent to the supplicant before timing out the session. The default is 2. |
RetryCount |
Indicates the count of the number of authentication attempts. |
